Discuss Motor cable - style question in the UK Electrical Forum area at ElectriciansForums.net
Lucien Nunes
Mentor
I'm about to replace the cable from a starter to an existing 2hp 3-phase 3-wire motor adjacent. The motor is rigidly bolted to a bed and has a direct shaft coupling, i.e. it is not on slide rails. Normally, I would use stranded singles in steel conduit with a flexible conduit link to the motor, not least because the motors are usually larger and 6-wire. In this particular situation it is more convenient to use FP because that can easily pass through the structure.
The obvious thing to do at the motor end is to make a loop of FP and take it straight into the motor terminal box, but for no obvious reason this feels cheap. Maybe it's the FP's solid conductors but you would do it with MI which is even more solid. The alternative is to terminate the FP into an adaptable box adjacent and make a loop with flexible conduit and singles, which adds a set of connections but for some reason feels neater. In other circumstances there might be an isolator in this position but as the starter is 1m away and has one itself there's no point fitting another. WWYD?
Seen plenty of MI looped cables at motors but not sure I would use FP as the loop, unless supported would be 'floppy'.
FP is a terrible cable, anything else has to be better! I'd be mostly worried about mechanical damage to the FP during motor maintenance activities. I guess you could sleeve it with Kopex or similar in the area near the motor to provide some protection. I'd also be worried about the solid cores fracturing over time with vibration, but as above I've seen loads of MI connected motors and those solid cores and rigid copper sheaths seem to last ok.
Use MI, it's way cooler than FP, you know you want to...
I keep various chain cables and H07 in stock here but this application doesn't need flexibilty as such. We recently slid the motor back to replace the drive coupling but that was possibly the first time it had moved since the mid 1930s when it was installed. My point is not that it needs any special treatment, but that I don't think I've ever connected a motor directly to FP before and it felt cheap and nasty.
Yes, I should have specced that in the beginning. The existing feed to the starter is MI too. I have a roll of 4L1.5 which would do perfectly but it's a long way away. I haven't done any actual install for the best part of a year and it's proving to be a challenge to get the normal bits together so I'm not looking to make it any more involved than it needs to be.
There might be a plan B here, in that the starter looks to be going a bit further away from the motor than I visualised. In which case I will put a rotary isolator right next to it and make the final link in steel Adaptaflex and singles.
I would say vibration is the key concern to consider, stranded cables are easy to terminate with lugs and are flexible, any solid drawn is a no no for me, a joint box and as mentioned earlier, some ho7rn-f which suits most oily environments.
Reply to Motor cable - style question in the UK Electrical Forum area at ElectriciansForums.net
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch šŸ¤Ŗ One we have been letting for over 20 years (as well as enjoying...
5K
My Current Setup (see image BEFORE.jpg): The wiring for my existing detached garage is shown (see image BEFORE.jpg). The house consumer unit...
Hopefully someone wiser than me can help explain some odd measurements Iā€™ve taken at my own home. This is a long read, Iā€™ve tried to give as much...
4K
Hi, Hoping someone can help me with a lighting circuit challenge. I have an existing two gang switch, with one 2C&E cable for a simple circuit...
6K
