J
Jimmy Boy
As my experience is mainly maintenance related and I am now venturing into board changes for the Part P registration process I would be grateful for heads up on your 'To do list' prior to changing the CU.
1) I will do a visual inspection of accessories and Main Bonding.
2) Check for contraventions of 17th in zones in Special locations. Advise accordingly
3) Now the board..Should I IR the whole installation using method 2 ie Line/Neutral clamped together to Earth ( This removes the requirement to disconnect vulnerable equipment).
Anything else ? comment appreciated .
ATB Steve
ATB Steve
