Discuss Resitance values on a 2kw electric heater in the Electrical Appliances Forum area at ElectriciansForums.net
J
Jason S82
Hi all,
Repairing a 2kw convection heater in our workshop office and I'm getting zero resitance on the min/max dial at any setting. What is the value for min and max as need to lever the spacing to get a resistance but don't know if it's too much or too little
Cheers
As a very rough guide a 3kw immersion heater will be about 19 ohms, so about 12 to 13 ohms would be able right.
What tester have you got?
It's the knob at min value and the knob at max value between the two spade connections at the potentiometer type dial I need the values for
Problem may be that you are trying to measure the element at room temp (?). I am a bit stumped by zero Ohms - can I ask what went wrong that you're having to repair?
That's the one, the stat is never closed regardless of min/max turned. So if functioning correctly it should be open or closed it doesn't have variable resistance?
No the stat is nothing more than an on/off switch with its sensitivity being controlled by the ambient temperature.
Reply to Resitance values on a 2kw electric heater in the Electrical Appliances Forum area at ElectriciansForums.net
Hi all, Wasn’t sure where to get some information, so I thought I’d ask the question here! FYI I have no electrical quals, I build custom...
Hello, Apologies if this type of question has been asked before. I have no gas in my house so rely on a water heater to heat the water tank. The...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
