Dougy
Solar panel details
Hello everyone
Im a new member to the forum, i have done a course on industrial electronics so im no expert on solar panel arrays etc,
Im thinking now of making up a solar panel array (off grid) to charge 24v batteries(2x12v) and use them with 24v to 240v true sine wave inverters for different ring main circuits around the house
I Have a 30amp solar charge controller with a load disconnect at 22.2v and load reconnect at 25.20v. float voltage at 27.2v
my Question now is i have solar panels with these specs below
Max power (Pmax) 245W
Max. power voltage (vpm) 29.75V
Max. current voltage (Ipm) 8.24A
open circuit voltage (Voc) 36.6V
Short circuit current (Isc) 8.90A
Max. system voltage 1000V
Max. fuse rating 14A
size 1637 x 992 x 50mm
if i used 3 of these panels in parallel (Max. power voltage(vpm) 29.75V giving a total of (Max. current voltage (Ipm) 24.72A would that be sufficient to charge the batteries or would 4 be better 32.96A on those not so sunny days
thx for you help everyone
I am not an expert on this, but one will come along shortly, and there are some good one's on here.
But I will try and help a little, panels are tested under STC (standard test conditions) so on a cool day with clear sunshine (I can not wait for that) they can and do produce more than stated, also on a hot day they will produce less.
From the little I know on this subject 2x12v through an inverter will not power much at all, and certainly not for long.
There was a thread on here recenctly about this very thing, try doing a search using different "key words"
I hope this helps a little for now.
Upvote 0
thx for your reply Earthstore i do understand that i will need a few more battery's i just need to work out the setup later for the circuits etc, i do have a 2500w invertor with 2 12v in series at 75amp each batteries, ive been running the house lights top and bottom circuits, all 11watt energy bulbs and a small 50W portable TV which i have been running not continually but for 2 days at present all still going well, il let you know when it gets dark lol.:cool4:
i will be getting more invertors and batteries for each different curcuit etc.
this is just in the early stages yet
its just the charging and setup side from the array im not 100% on
Upvote 0
Dougy,
Dougy,
