1Justin
479
171
118
Surrey
Business Name
Circitas Ltd
Hi, I'm pretty new to this but a first job (and remember the nice man from NICEIC etc needs to be impressed:)), requires me to extend cables which will be left maintenance free beneath floorboards. - It not being possible to take them back to source.
I've read many of the posts on crimps vs Wagos and boxes. Ignoring the Wagos right now, I have just bought a ratchet tool and some (cable clamp type) choc boxes, idea being to crimp the cables with insulated butt-crimps, enclose all in box (screw cable clamp type). I also have got some self amalgamating tape on the way with the intention of perhaps (or not) going round the whole thing.
Is perhaps the S-A tape an overkill? Maybe I should embrace modernity and begin with Wagos as I mean to continue?
If I do heatshrink instead of the boxes (I have no coloured heatshrink right now -only black), I was supposing it best to offset the three joints, over shrink L&N individually then overshrink the lot (or use self amalgamating?).
What grade/dia of heatshrink is recommended for red (1.5mm), blue (2.5mm) or yellow(6mm) size crimps? And also since I need to crimp 4mm cable, is there a crimp size missing here?
Just a word of caution why you should never pull energized cables around.
The crimp you can see is the line conductor - found this done by a kitchen fitter who had fitted the lady's kitchen 2 years ago to extend the ring... the opening must have originally contained a socket outlet that the guy removed and he shoved this bodge to the side, (the opening is not covered with a blanking plate) it is located under a worktop behind a dishwasher so is out of sight normally..
This was meant to be a simple job but I found almost everything the guy did of poor workmanship or none compliant, not a single grommet used, not a single back box fly lead, spurs off spurs, as you can imagine the lady never received a EIC... The not so funny thing is he told her he was giving up the install game to go and teach electrics at a college....
Reactions: 1 person
That don't look to good but without sounding rough , didn't think grommits were required by regs, just good practice, and fly leads are not required if there is a fixed lug on the back box
Yep rough is the word, I did write poor workmanship or none compliant, none of the back boxes had lugs, I could have listed everything but it would have been a big post...
I just wanted to warn people there are non safe installations are definitely out there...
Ah well you learn something new everyday... many thanks.
I can't remember if it was an assessor or lecturer that asked me a question many moons ago about fly leads, I said something like 'its good practice to fit them in all cases' and he replied he always wanted to see them, so I guess he is the belts and braces type, I think I'll always still fit them as personally I think it looks like a more thorough job and takes little time.
So I guess the size of the fly lead needs to be the same as the cpc size? never really thought as I always just strip a bit of the T&E I am using but could you use a bit of 1mm for the fly lead on a 1.5mm ring cpc?
Reactions: 1 person
OK, getting this thing back on track.
I don't generally go in for cheap tools, but now and then succumb for a moment for a cheap reality check, before I realize I was right all along.
I was passing Toolstation I bought a cheapo crimp tool ("expert" ratchet crimper ahem :lol:) and some insulated butt connectors (blue). A load of test joints later, and I don't even need to test these. - They wobble, even with the tool wound up to max. I have my table covered in little test pieces and I just can't get a tight joint.
Maybe the bolster really would have been more effective! (So just for fun Geordie, I clouted one with a blunt bolster and guess what - it really did make a better joint!!)
Please don't say "I told you so"..Like I said, I test myself now and then with cheap stuff. Sometimes there is a pleasant surprise (but not often).
I'm going to buy a better one tomorrow, and this will go back. (But would that make me criminally negligent because someone else might just try and use it?)
Reactions: 1 person
1Justin
Surrey
Business Name
Circitas Ltd
Wagos or crimp?
Australia
Thread Tags
1Justin,
1Justin,
