Amp David
Mentor
Supporter
Oct 2, 2009
4,930
915
10,239,798
Glossop
Looking at this picture, what size CSA would you the black bit of cable is?
For reference working fronm left to right we have
2.5mm, 4.0mm, ?mm, 6mm
ahhhhhhhhh should be AWG 12 then but not bad without the conversion books, I hate AWG it's the cheapiests nastiest stuff in gods green earth.
I've been told by the old boys that it is possible to order any size, any colour, any core you want from a manufacturer. Why they would go for this in-between size is any ones guess. I think it may have been a bad batch of what should be 6mm, sold cheap and still used. How many strands does it have? (how much can we debate this 2 inch of cable?)
Its made up of seven strands.
Because they're yanks mate, they only have inches
Yeah, I know that. What I was meaning is why is it being used here in the UK, would of thought that in 1989 it would of been metric.
Can't see it being an odd off cut either, as there are 11 houses with the same install into the garage, all with a run of 12 meters.
try measuring the resistance. and swg is english, it's them damn meters that are foreign. meters are for putting shillings in to make the lights work
standard wire gauge. as on 7/029, now replaced by 2.5mm. the 7/029 was far superior. just done a CU change where most was 7/029 for ring finals. 3/029 for lighting. all readings well perfect and it's 40 years old.st on case you don't know already. the 029 is the swg of each strand, and the 3 and 7 are the no. of strands.
Ahhh...now I remember. 7029.
It is all stranded, including the cpc.
It had a shiney outer insulation compared with todays T&E.
Mostly, when ive been involved with it, during rewires its been ripped out because its part of a rubber installation (due to additions and alterations), it was always replaced with modern solid core PVC. I think it has a tinned ingredient to the copper?
Im sure the stuff is probably fine.
Edit.....infact I think the stranded cpc on 7029 might be a larger csa than the solid 1.5mm found in 2.5 T&E?
Take it the 029 is 0.029 inch diameter of the strand?
nope, strangely, the bigger the number, e.g. 029, the thinner the wire. wikipeda has a metric equivalent chart. google standard wire gauge.
Reactions: 1 person
yes, the rubber insulated older stranded cables have mostly all now perished, the later pvc are uaually still as good as new. and you are correct. the cpc was usually greater cross section than now
Amp David
Mentor
Supporter
Glossop
What CSA would you say?
Australia
Thread Tags
Tags Tags
csa
Amp David,
cagedanimal2010,
