Discuss RPM on a digital dash in the Auto Electrician Forum area at ElectriciansForums.net
Sorry, my point was you can't doc things like that with all this digital stuff!
I'm not trying to clock anything. This is a brand new kit car so the digital dash starts from 0 miles anyway. My problem is the rev counter no longer works.
Ag4CZijMHhXfjFuDpaJOaksnAeBu8Itjz-Wcgftciic=s648-p-no
6pEz8-mq-77z-_ZCaLMIm66xCSZX_l0Pv7y7xxaXjYo=s648-p-no
Like it. I too have a motorsport hobby. Built Megasquirt ECU on a 6 cyl BMW, one with wasted spark one using a single coil. I too had to derive a decent tacho feed for the existing BMW dash. As mentioned high level always refers to a signal off the ignition coils, whereas low level is a clear signal derived from the ECU using the crank sensor. Unless you use the correct one, you wont get a reliable signal. Looks like you are nearly there, cheers P&S
Well I tapped the dash into a wire running from one of the coils to the ECU and it picks up the RPM fine now! On the scope it was reading around a 4v pulse so I connected this to the low RPM feed.
How do you get on with the MegaSquirt? I've seen Mazdas with them on but the Westfield factory recommend Omex instead.
Maybe I should add a MegaSquirt to my E46 330 :)
It was over 5 years ago I built the MS2, I know they have brought more out and its getting cleverer and harder to build yourself. For a N/A simple car like the BMW E30 I have its more than adequate. My main reason for going down the MS2 route was cost. Its dirt cheap and a great way to get into ECU builds and mapping. The great thing about MS2 is there is an awful lot of it about its totally open source with a great backup. The realtime output screen of the engine parameters is really useful and well laid out.
do you have any links? im quite curious i do like watching programs etc on car's and mechanics etc
Reply to RPM on a digital dash in the Auto Electrician Forum area at ElectriciansForums.net
I am rebuilding a track day E3O which had a M52B28 conversion ,the rev counter installed was a RMD brand which worked fine but I had to dismantle...
I wired in an auxiliary fan to my Jeep radiator. Details: 1. Fan grounded to body. 2. Power wire for fan goes to standard 4 pin relay (with...
Hi, I'm trying to rewire an old plug. I've rewired a few in my time, but all have been with the post-2006 wire colours. I have this old welder...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
