Interesting - didn't think anyone made one and assumed maybe the standard required screwed terminals. Though the terminals didn't help in this case apparently, but can't really blame them if you put 26A through it...
Not going to catch on unless there are 3 terminals per socket though.
or 4, for the DIY market
It's a standard Legrand dual socket the small finger points above the push in connectors are to relive the push fit and allow the cable to be retracted, it did have three connectors at some point. ? Its a French standard fitting.
its not bullying.... its ignoring the health and safety procedures that have been put there to protect you and your workmates.
to put the poor lad into danger knowingly could lead to claims of historical abuse. I'd watch your back if i were you.
Theyre catching all sorts of historical misdemeanors nowadays from racism and sexism... so i wouldnt be surprised if apprentice baiting became the next big thing?
Who're you trying to kid, short ---??
How much power was connected to this outlet? 3 kW?
No idea, but the house was three phase and only 20amps/phase, 20amp MCB on a row of six others all covered by an RCD.
Reactions: Dartlec
You started it!
is a short --- a little donkey, little donkey on a dusty road??
Started what???
Obviously hit the wrong button there, didn't I?
It was just a joke, having a go at folk picking on folk and bullying. If you can't get that.... then I'm sorry.
Enough. Good night.
Loose connection
Is that 3 phases through 3 separate holes in the metal baseplate?
Ah that's ok then! Must be my old eyes?
Just threw these out during a clear out - only time I ran into melting MCBs on a job, some years ago now.
From memory it was a loose terminal on the busbar so installation not manufacturer's fault, though did put me off the 'cheaper' brands for a good while...
I’ve posted it before but this is what happens when you put 230V through a 110V coil. The coil voltage was applied whenever the machine control was on, so it would easily be sitting at the over voltage for 8 to 10 hours a day. I think it lasted three days before failing.
Physically the contactor looked fine, but you couldn’t manually push the contacts together like you should be able to.
Always always always check the coil voltage as well as the contactor rating, don’t just rummage around the parts cupboard for something that looks similar!
There was a poor connection in this outlet. The clamps in the outlet are loose. The contact has warmed up and the socket has melted!
When electrics go wrong!!!
Darkwood,
mickegh,
