Discuss trouble with newly installed MK c/u in the Australia area at ElectriciansForums.net
Is the neutral blocks linked out.??????? Hard to make it out properly
When Tony sees this I reckon there might be a bit of a -------ing lol
thats the way it came :/ never used an mk board before
Are you being serious?
yet again im shocked to what basic knowledge an electrician has, very worrying some of the posts you come across on this forum
Id identified that problem within 5 seconds of opening the photo, more than likely because im time-served, and im pretty sure others identified it too
me too. the main switchy is on gthe wrong side of the board. :hurray:
Well if page 6 of this thread isnt enough of a clue, i reckon he should see if he can get a job collecting bins or cleaning windows maybe, even then that still requires some degree of common sense
Just realised the original date this thread started 22-8-11, certainly glad i wasnt your customer, how incompetant must it look leaving someones property in a state of fault for well over one month, i can only presume RCD has been linked out to overcome your problem
Jenions the neutral link is present in the board so that you can put more circuits on one side of the CU and use the third unlinked neutral for another RCD. Because of the circuits design you have, you only need two circuits on the first neutral bar so there is no need to use the link. If the link is left in the current in the neutral can bypass the RCD so it sees a difference in current between line and neutral current and trips. Remove the copper link and this should solve the problem.
A picture is worth a thousand words..... (even a very small picture!!!!)
it'a a bad layout anyway, as he has only 4 N terminals for the 5 RCD circuits.
I'd say that was because it would originally be a 4x4 split load board and he has been playing around with that set up
I am not reading the whole thread, but that appears to be the reason where the glaringly obvious problem he has had originated from
He must also have ( knowingly) extended the bus bar to make that set up
Well that's given the game away :D
He could use the link. There’s a neutral bar sat there doing nothing! The neutrals could be spread out to tally with the MCB’s then. And as for the 2[SUP]nd[/SUP] MCB from the RCD what’s coming out of that?
annoying thing is, the rcd dont trip if you plug small loads in
Could it be a combined earth leakage issue as it only happens when sufficient load has been applied? Have you ramp tested the RCD and used an earth leakage meter to see? Possibly a certain appliance causing the issue - freezer maybe?
Could it be a combined earth leakage issue as it only happens when sufficient load has been applied? Have you ramp tested the RCD and used an earth leakage meter to see? Possibly a certain appliance causing the issue - freezer maybe? That's what came to my mind when you mention the IR results were ok?
You can, as with MCBs, put more than one circuit into an RCBO but it's not good practice.
Not technically possible as it then becomes one circuit. So you could have multiple cores rather than multiple circuits in the protective device.
Reply to trouble with newly installed MK c/u in the Australia area at ElectriciansForums.net
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Doing one more of the flood of EICR today on a rented property before a tenant change, but ran into a slightly interesting case so would...
13K
Hi guys I have this problem that I've been trying to figure out all week. On friday I had a 5 tail economy 7 smart meter installed and every...
7K
Hi Don’t often post on here but I’ve dreamt about this issue last night. Need advice please Yesterday I attended a property to complete an EICR...
Toneyz
T
Hi all, Any help would by greatly appreciated as i have tried everything i possibly can. Heres some info on the situation, installed some spike...
