G
gary5461
I'm a novice but willing to learn. Go easy on me! re above. I have upper and lower rooms. Should I run two socket circuits or one? Total double sockets I have is 20. Boat is 15m long, 4m wide.
thanks telectrix. advice appreciated. Common sense when I think about it. I was off at school the daythey did common sense ? my '2nd' circuit upstairs would have at least 15m of cable from fusebox before 1st socket and the same back to the fusebox after last socket but I guess that's OK.i would run 2 ciruits, then if you lose a circuit due to a fault, the other one is still in service.
Hi there I plan to put underfloor heating on one supply which calculates at a maximum output of 23 amps and on the other I was going to put the oven and shower. Plus electric sockets but none of granny's heaters!What will you be using on your boat? The TV, DVD player, phone chargers, kettle etc? or several of grannies old three bar heaters?
What kind of shower?on the other I was going to put the oven and shower
You might want to rethink your design.Hi there I plan to put underfloor heating on one supply which calculates at a maximum output of 23 amps and on the other I was going to put the oven and shower. Plus electric sockets but none of granny's heaters!
