Discuss BS fuses V's DIN and VDE in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
Lighthouse Phil
Hi Lads, anyone know what the difference is between the standards of BS fuses and the europeon standards of DIN and VDE fuses?
My supplier of switch gear is now telling us that there is now going to be a leading in time if I want to buy BS fuses, as they have to be imported, whereas DIN and VDE standard fuses will be off the shelf...
I know there is a difference in the breaking curve and testing standards of the two, but what does it mean to the designer for a bog standard 63A switch disconnect ?
PS, Based in Ireland
Hello Phil,
What supplier are you using? RS stocks a wide range of BS fuses with next day delivery. RS has Irish branches, ask them for a second opinion.
Thanks for the reply stef, I'd have no problems getting the BS fuses elsewhere and would have a good stock of different types, I was just wondering what the difference was between the UK (BS) standard and the europeon standard.
Yes Chrish, thats what I was thinking, harmonised and all that......but I did find that the DIN / VDE fuses are tested to a higher voltage....I wonder if thats the only difference ?? I think I'll be phoning a europeon manufacturer soon to see if they can answer my question. Hager have a good customer service desk who speak English.
Reply to BS fuses V's DIN and VDE in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Someone asked about abbreviations used here. So I tried to copy a list I made elsewhere: A/C Air Conditioning AC Alternating Current ACB...
5K
Is there a room in professional PAT testing for a business model other than 'per unit'? I ask because I've been giving this some thought. I've...
9K
P
Hi, I'm not an electrician, I wonder if anyone can help me with a few queries. Q1. Can you explain what this 40A RCD might be for (Off Peak F)...
4K
I have read a few posts with regard to Reg 421.1.201 & Similar Switchgear Assemblies, with regard to the definition of such. When 421.1.201 came...
4K
