M
Mark Shields
Replaced panel and would now like to replace Bell box.
Using Existing wiring, it has two cores from bell box wire to an individual zone, so only 4 Spare cores available at bell box.
I cannot even find the possible 'zone/pir/panic button' to check the wiring at it.
Can anyone help me out....
Can I do away with a tamper rtn and link it in panel?
Many thanks.
Mark.
Hi Mark: Having anything else running with the sounder cable is really a no/no & the cable should be replaced but if that's all you've got:
G4 T to AG6 TR-. G4 A to AG6 V-. G4 D to AG6 V+. G4 B to AG6 S-.
Will give you a working box with tamper, if you want the strobe then drop the wire between T/TR- & instead wire between the - terminal on the g4 sounder block to ST- on the AG6.
Can I wire up a Honeywell AG6 Alarm bell box with only 4 cores?
Security Alarms, Door Entry and CCTV (Public)
Mark Shields,
Mark Shields,
