Discuss Can tubular heaters be mounted vertically? in the UK Electrical Forum area at ElectriciansForums.net
Percyprod
As in title, can a tubular heater be mounted vertically? Doesn't sound like a good idea to me, but it would settle an argument if some one could answer.
Why would mounting a tubular heater be a problem Percyprod? I can't see a problem, in all honesty.
I was wondering as you say if there is a thermostat fitted would it be affected by the top end getting hotter than the bottom, so affecting the temperature it operates at?
If it is oil filled, there is the possibility that the end of the element could be exposed resulting in a possible hot spot and premature failure of the element.
I would suggest you read the manufacturers instructions carefully as they are likely to provide guidance on such matters.
It won’t work effectively. The heat would be higher at the top obviously.
If thermostat at the bottom, the far end of the element could melt before the stat cuts out.
Conversely, stat at the top would cut off before the desired heat was achieved.
I’d be certain the instruction will stat horizontal only
By the way, avoid Heatstore if you are buying, put two in a large wardrobe with cold outside walls a couple of years ago and have replaced one twice and the other once, the end connections melt.....and no, they are not covered and yes they have a guard
Reply to Can tubular heaters be mounted vertically? in the UK Electrical Forum area at ElectriciansForums.net
How would you personally Code a Tubular Heater that was fixed to a Wall Horizontally with Two brackets. The Heater being about a meter long but...
Hi all I'm after some advice on 2 way CU in a garden office which is 'buzzing' when I turn on or increase the tempreture of the wall mounted...
Hi. I know this probably isn't the most fitting platform to post this question, but I was racking my brain where I could get an answer to my...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
