Discuss Computer mouse in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Currently I'm using the keyboard on my laptop.
When I'm in my office I have a docking station which connects, among other things. a full sized keyboard. That has a scroll lock key and it can cause some odd things to happen.
Thanks for trying to help mate, but it was dust in the end, I would have never guessed.
Glad you got it fixed.
This came into my works email eons ago and it might amuse you in light of the thread topic:
This apparently was a real memo sent at a computer company to its employees in all seriousness. This memo is from an unnamed computer company. It went to all field engineers about a computer peripheral problem. The author of this memo was quite serious. The engineers rolled on the floor.
[h=1]"Mouse Balls" [/h]Mouse balls are now available as FRU (Field Replacement Units). Therefore, if a mouse fails to operate or should it perform erratically, it may need a ball replacement. Because of the delicate nature of this procedure, replacement of mouse balls should only be attempted by properly trained personnel. Before proceeding, determine the type of mouse balls by examining the underside of the mouse.
Domestic balls will be larger and harder than foreign balls. Ball removal procedures differ depending upon the manufacturer of the mouse. Foreign balls can be replaced using the pop-off method. Domestic balls are replaced by the twist-off method. Mouse balls are not usually static sensitive. However, excessive handling can result in sudden discharge.
Upon completion of ball replacement, the mouse can be used immediately. It is recommended that each replacer have a pair of spare balls for maintaining optimum customer satisfaction. Any customer missing his balls should suspect local personnel of removing these necessary items. *
haha, so now we know MDJ stands for Mouse Dust J. :smilielol5::smilielol5::smilielol5::smilielol5::smilielol5::smilielol5:
our wireless plugged ito an adaptor from the scullery light. has to swap it for the iron on washday.
Your place sounds like a mirror image of ours until the day a new light switch appeared on the kitchen wall with a toggle to work the light and a two pin socket to plug things into. I think it must have had a L&N feed from the fused-neutral CU.
Reply to Computer mouse in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
5K
Hello, Not an electrician and I currently live in an apartment building. Over the past few years I have been having abnormal problems with my...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
