Search the forum,
Discuss Contactors : and how they work in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes Luke, this is done as well.
I have used large contactors where there are fixed terminals for the neutral in and out, or an additional set of contacts for the neutral
The contactor you have shown is 3 pole, so could be used for three phase (L1, L2 and L3)
or single phase using two of the three contacts to switch line and neutral
- i dont know if you are aware, but a lot of industrial three phase systems (particularly those supplying motors) dont use the neutral anyway!
Reply to Contactors : and how they work in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
Hi brains trust, I am aware of typical wiring and legalities hence the questions. Looking for a wiring diagram to allow me to use a dual switch...
We are a UK registered Electrical company with a large contract based in and around Toronto, Canada. Are you looking for work? We have a...
