Discuss I'm not an electrician but I some clever heads together in the UK Electrical Forum area at ElectriciansForums.net
If I put my computer on the floor rather than on the computer shelf will it be grounded?
Ha, ha very droll!:) To understand ground circulating currents you have to understand the relationship between capacitance, inductance, voltage and currents in a computer system. Circulating currents can cause problems when output currents cause a difference between the actual output voltage and the feedback voltage as well as when the output ground currents move the power supply's analog ground off its true ground. They also cause problems when the output current in the supply and ground rails interfere with the delivery of an accurate voltage to the system and when the circulating currents are in loops which then radiate excessive electromagnetic interference into the system causing it to fail. Thinking about it, the only way to destroy this many computers with ground circulating currents, is by corrupting their bios chipsets. Are you sure you are not loading some computer virus onto your systems?
My eyes are bleeding :cool:
Wtf does all that mean? :mkungfu:
Whoozzzze something flew over my head :rolleyes:
I think I'm out of this one now. Been quite entertaining though! Thanks :) Daz
Well there is one breaker marked Solar PV that could be a clue...
But my gut feel is an issue via the HDMI or DVI cable. What's the monitor connected to the computer.
Benq monitor bought new in 2015.
It was happening before on my old Asus monitor
I had a new motherboard GPU ram and PSU replaced in November this year. I decided to rule out the monitor by using the computer via my TV with brand new HDMI cables to rule out the old cable.
I also bought new mouse and keyboard to rule out any fault on the USB
I made sure I used nothing else.
Within a week it happened again and the GPU failed
Reply to I'm not an electrician but I some clever heads together in the UK Electrical Forum area at ElectriciansForums.net
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
Like a host of UK residents recently (230% increase in genny sales apparently), I've just invested in a small (3500W) portable, dual fuel...
