Discuss Intermittent MR16 downward lights in the Lighting Forum area at ElectriciansForums.net
Hi all. Just moved into a new home and I've got 4 of the kitchen downward lights that are out. Tried changing the filaments but it became obvious that the filaments are fine, it's the wiring into the back of the socket that's at fault. My question is how do you de-wire these MR16 GU5.3 sockets? There's nothing obvious on them to unscrew, unlatch etc? The two wires out the back disappear into a false ceiling with no disconnect point there either. I think I'm going to have to cut the wires close to the mounting, strip them back and then splice the two wires from a new mounting onto the old cables? Bit of a pain.
On the bright side I've now got 4 spare filaments for future use!!!
Thank you,
Steve B
These are low voltage lamps (12 volts), so somewhere between your fitting and your mains supply, is a transformer if some kind.
Much more likely it's this that has failed than the GU5.3 socket.
if it’s just a simple bezel in the ceiling, the fitting is likely held up by springs. Just needs carefully coaxed out the hole. The transformer will be nearby.
Be careful of fingers! The springs are strong.
Also, if the mr16’s are old halogen type, you might find the ceiling plasterboard is dried out and crumbly where it’s heated up.
Reply to Intermittent MR16 downward lights in the Lighting Forum area at ElectriciansForums.net
Hello and thank you in advance for your time in helping me troubleshoot my lights. I've added a video to show what my lights are doing. I have...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
