Discuss Part P :: Cooker switch, Distance from Cooker Hob in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
DaveyD
Hi
Looking at IEE's guide to building regs in 5.2 Kitchens: I understand that sockets should be > 300mm from a sink (5.2.2 iv) and cooker switches should not be over the hob (5.2.2 ii) but only the illustration shows 300mm for the cooker switch nothing in the text. Would you think a Napit instector would pick up on a cooker switch 200mm from the hob?
Thanks in advance.
Kind Regards
David
As far as Im aware, there isnt a minimum distance away from the cooker, as long as it isnt directly above it, then it should be fine.
The 300mm you are talking about refers to distance away from the sink, so as long as the cooker switch isnt close to the sink aswell then I cant forsee any problems.
Thanks you Dazza, it was the fact it mentioned 300mm in the illustration - a mistake?
look at it another way;
an outside switch is protected against the ingress of water because it is outside, if a switch is near a source of heat...
It's recomendation, >300 rule. as long as you as the designer of the installation are happy that the posisition I'n which you have located it, is practicable and there are no other factors affecting it's safe operation 200mm should suffice.
Let me know how you get on. good luck. This will clear things up
The main problem with cooker switches too close to the appliance comes when it has a socket outlet. What you need to avoid is the possibility of someone plugging something in, and then putting the plugged in appliance down onto a hot hob, or the hob getting turned on with an appliance sat on it (like i did whilst drunk on holiday one year and destroyed a toaster). So if the cooker switch is a bit too close and it has a socket then replace it for one without a socket. Obviously common sense should prevail if the thing is just too close altogether.
Cheers........Howard
Yes it has a socket. I think its fine at 200mm and dont want to move it right again right in a corner BUT wonder why no mention in text just in illustration. Anyone know of where the text is for >300mm from a cooker hob? I want to get this right.
Kind Regards
David
Reply to Part P :: Cooker switch, Distance from Cooker Hob in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, a landlord got in touch this weekend as they wanted to change an old gas oven for an electric one in their rental property. It would be a...
9K
ELECSA Certification Scheme Regulations Clarification (ELECSA Assesment)
Hi All, I have my ELECSA assessment in a few weeks time. I was going to install an in-line water heater at a friends house but am now considering...
9K
S
Hi All, The plan is basically: Drop the ring main from upstairs, to a surface mounted socket just beside the hood, put a plug on the flexible...
4K
Have come across a 10mm t&e supplied from 45a 60898 installed a/c. This runs into back of cooker switch back box- terminated into 45a connector...
