Gavin A
- Jan 20, 2012
- 4,122
- 1,135
- 2,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Other
- If other, please explain
- Solar installer for 15 years
- Business Name
- Leeds Solar
indeed. they're also a pretty pointless way of spending an extra grand on a system for most people.
The full scan function ensures that the inverter doesn't get stuck on a false voltage peak as the shading impacts on more strings of cells, and the optimum voltage moves to a point where the bypass diodes have cut out the shaded strings.
The new OptiTrac Global Peak makes sure that partially shaded solar power plants operate efficiently
