G
Graeme Moo
Can anyone tell me a PRACTICAL reason for installing RCD plugs to class 2 site equipment, and how do i PAT test the actual appliance without removing the RCD plug?
Discuss RCD Plugs in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
The RCD unit measures the current in the live and neutral using sensitive electromagnets.Where there is no fault condition, both readings will be equal.If you were to touch a damaged cable even on a class 2 appliance and provide a path to earth, the unbalanced current measurement would cause the RCD to trip, thus saving you from an electric shock, so they are fitted for a very good reason.
Hope this helps.
Reply to RCD Plugs in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
