J
Jim
I have a new bathroom mirror with lights which works ok but makes a constant buzzing noise whether it is turned on or off.
It wasn’t installed by me, but when I remove the front I was surprised to see that it has been wired using 2 electric wires - see attached photo.
As a complete novice I was wondering whether this was correct and perhaps this was the reason for the constant buzzing?
Would appreciate any help please.
Best call an electrician Jim, without being able to trace where these two cable go to or come from its difficult to advise, there could be a Forum member close to your location who may be able to help you out, to far for me to visit.
If it has a shaver socket you may well be hearing the isolating transformer.
Possibly OP referring to lack of earthing? Does the luminaire have one of either of these images on it or in the instructions;
2 wires means the supply is looped - not unusual in the least.
Live pair in and Live and SL from switch, which is which is my question.
Seems wired correctly to me.
Reactions: SparkyChick and Zdb
Guess we will never know unless Jim gets a sparky in will we.
Transformer casing is Loose and may need spray lacquer or hot glue to stop buzzing if new mirror replace.
the wiring is not the problem
Where do the Brown and Blue wires go to and where is the Mirror light switched from, is it an integral switch?
They normally have a pull switch, internal switch behind one of the doors. The supply is permanent live.
99% of them have some form of switching built in so that the shaver points are always live
Agree but do we know for sure? if it's a loop feed as you suspect, where is the loop going?
there's a lot of exposed copper in them terminals ( or should it be termini.? :p ).
Reactions: LankyWill
Connections, Tel Connections, or Connecti, you could be onto something.
Thanks all, really appreciate your feedback, and reassuring to know it’s not the wiring.
Yes there is a shaver socket, which we’re never going to use, as well as a motion detection on/off switch for the light.
Nothing in the 1 page instruction manual with those logo’s. Reluctant to take off the front again this evening, it’s a pain in the soandso to get on and off!
The make is Opticon. It’s a replacement, the first one had Bluetooth and was terrible, we swapped after a week for the basic version but it’s also making buzzing noise. Relatively cheap, I guess you pay for what you get in life, but otherwise it looks great and I have to be fair, the customer service has been very good on swapping the 2 items.
Maybe I need some of this hot glue you mention. Can I buy from BBQ?
Bathroom mirror wiring wrong?
Jim,
Dave OCD,
