- Sep 18, 2019
- 14
- 3
- 33
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
- If other, please explain
- Homeowner
Hi
Having my flat re-wires. It’s on the first floor, with no disabled access. Electrician is saying light switches have to be a max of 1200mm from floor (about 400mm lower than their current position!). I realise that this is the standard for new builds - but does it apply to old properties being re-wired? (and, if so, what reg does this come under?). I really don’t want my switches that low!
Thanks for your help
