I vote to go back to the proper colours!
Red, white, blue for L1, L2, & L3
Green for neutral
Black for earth.
Yes, EARTH, none of this fancy "CPC" stuff!
Proper colours I say!
We can then have a proper notice to 514.14
"...This installation has colours to "s*** loads of versions of bs 7671..."
And we should go back to IEE, none of this IET lark...
And don't get me started on the size of "wagon wheels" today, when I were a kid, they were big enough to replace a three course meal...
At first I thought that was a spoof article, or April 1st joke.
Then I realised how much of a joke we all are now :(
There is an IET article "The history of colour identification of conductors" (google to find it, links borked on this forum) covering the UK history of colours.
It also has a note by someone involved in the decision for brown/black/grey explaining how it was a combination of the Uk being late to the party and then trying to wrangle a least-worst compromise with others in the EU (and wider) where various colours were in use a CPC so effectively forbidden for phase use and a high risk to life if standards attempted to change that.
you think that's bad. try googling "woke".
Red/Yellow/Blue.
Feet and Inches.
Pounds and Ounces/ Stones, Cwts.
Rods, perches, chains, Fathoms. 4 rods = 1 chain.
1 Acre is 4840 sq/yards. the area 1 man with horse and plough could turn over in a summer's day provided that the pub was closed.
Gas bills worded as xp /cu.m so we can gauge the cost. maybe converting the meters to cu.feet. is a step too far.
Reactions: loz2754
Red/Yellow/Blue.
Feet and Inches.
Funnily enough at one point the phases were called
Phase ------------ cable colour
Red (R) ---------- red
Yellow (Y) ------ white
Blue (B) ---------- blue
I kid you not!
strangely though. D.C. ELV is still red/black, so why is FP200 brown/blue. must be a gender (or some other snowflake fad) thing
Colours were still red and black when I was in college, it changed the year I left and part p was brought in.
Flex has been brown and blue for as long as I remember so why do we need the label on the distribution board?
Because flex isn't generally used as part of the 'fixed' wiring in homes
I was fortunate that I managed to get about 10 years using red and black cores before the powers that be forced us to change
Still odd though that they think a warning was required when we already knew of the two schemes.
Do you generally see the changes in regulations as an improvement in terms of working practices and safety?
It wasn't just changing red and black , we also changed 3c phase colours to brown black and grey so we had to de-neutralise the black and turn it blue.
I think the labelling was for unsuspecting plumbers , kitchen fitters and DIYers who had little knowledge of the phase colour changes...
As for improvements , NO not at all. Part Pee , cable changes and metal boards have made little to zero health and safety advances. Its all just been a money spinner for the powers that control us IMO
Yeah I always have to consider the de-neutralising the black, I wasn't aware of the article for quite some time and thought it was logical to keep it as black.
It's a shame that the iet didn't address the issue that companies like mk produced crap that wasn't fit for ce marking and instead mislead people about consumer unit fires.
I also agree with you on part P not working.
There's been improvements though like the use wago's, rcbos and fire resistant fixings.
To be fair, the colours were RYB Black & Green (or Green/yellow) when I started, (new colours for flex), but virtually all the older properties were in previous colours RWB Black, and either bare or Black for earth. No label on cu then!
Also, some were still RWB and Green (neutral), bare earth.
Again didn't need a label on the cu or dist board
You had an earthwire?
We’re going to end up with cyan, magenta and yellow…. Oh… no. that’s taken
I wasn't aware of the green neutral, perhaps I just haven't paid enough when stripping things out. Was that at the same time as the lead sheathed flat cable? Or the vrf stuff?
Every cloud, as they say...
If we went back to red and black, all those drums of cable in my garage will suddenly be reprieved!
Along with the drum of twin red...yay!
The plain green sleeving is from very old installations… 60’s and 70’s. Not quite as old as lead.
Lighting circuits were lucky if they even had a cpc!
It was around the same time frame as the insulation that breaks down over time and becomes “green goo” which ends up dripping out of sockets.
I kid you not!
Here you are Julie - here's some Red White and Blue for you, even triangular conductors!
Reactions: Julie.
I have a list of dates to help me date cables:
Red and black '50 - '04
No earthing - pre '66
Polyethylene - '50 - '60
PVC - post '60
Tinned copper - '60 - '70
Green earth - '66 - '77
Green goo '68 - 75
Imperial - pre '72
Aluminum - '72 - '76
2.5 t&e with 1mm earth - '69 - '81
Please enlighten me if I'm wrong with any or if there's anything else that could help.
Green neutral is really old, pre war really (it changed mid ww2), but when I started, it was only ~35 years old at that point.
It was common to find installations still in service after 40 - 45 years, I think less so today as the regs change so frequently now - 18th had ammendment 1 in less than 2 years , the 14th edition basically lasted ~24 years, the only change was the move to metric sizes!
Green for neutral
Black for earth.
Indeed I recall when wagon wheels were so big you had to actually wheel them home!
Reactions: Julie.
Reactions: loz2754
If you strip any of that out I need it for the museum!
It looks like it might be quadrant (4c) rather than 3c , but can't really see on my phone 🤓
Just imagine them singing 'I can see for kilometres and kilometres'.
It would be a disgrace.
That's why we still use miles...... not many know about 1760 yards, though.
It is there for idiots. Had a 4th year apprentice working with me recently and he was baffled by 3 phase. Had absolutley no idea why it was RYB and claimed never to have seen it before. Needless to say after seeing his work I'd be scared to think next year he'll probably be out working on his own for a company no doubt.
Reactions: westward10
also........
Reactions: ipf and nicebutdim
When I started work all dimensions on drawings where in imperial with the metric equivalent in Millimetre's in brackets underneath never used Centimetre's or come to think of it Meters.
An apprentice? I've seen 5 day Part P jockeys trading the next week.
It is recommended to only use multiples of 1000 (so um, mm, m, km) and not cm as it becomes far more obvious in the "unit" is wrong if out by 1000 instead of 10.
I have had some stuff machined to 1/10 scale as a result of that sort of mix-up!
when i started meters were for putting shillings in. rememember my dad telling me to put my pocket money in the "safe" under the stairs
We don't have the 5 day wonders here as far as I am aware, but then I don't get involved in the domestic market. What amazed me was how confident and cocky he was even though after 4 years he didn't know cable colours, how to fit a occupancy sensor or what a contactor did. Incredible
  • Funny
Reactions: nicebutdim
Yeah, the use of cm really annoys me, there are preferred multiples/units.
Most come from latin so...
Instead of 1/100th - (centeimus) -
centimetre
Perhaps we should start using 1/20th - (vicesimum) - vicesmetre, vicesohm, vicesvolt.
That piece of cable is only 10vm long, it has a voltage drop of just 1vV.
That's going to mess them up!
centimetre
let me get a 50cl 1 gill of scotch and i'll re-read that.
  • Funny
Reactions: pc1966
Can we also go back to red & black wires please...
Dustydazzler,
Mike Johnson,
