- Dec 9, 2008
- 13,496
- 18,280
- 3,557,381
- United Kingdom
- Other
- If other, please explain
- C&G 17th edition regs
C&G 2382-18 (18th edition regs)
C&G 2394 Inspection & Test
C&G PAT
2 x BPEC electrical courses/exams
Thanks Mike. Alas, the screw heads are about 5cm into the casing via moulded tubes. They are quite small and may be spline headed but v. diff. to see.
Buy a multi bit screwdriver set. Won't cost much for one that will cover most things. Just make sure it is a long reach set though!
