I want to protect a MOS FET for ESD with a bidirectional TVS diode. The MOS FET I have has not a built-in TVS diode. The max gate-source voltage (Vds) is 30V. Shall I chose a TVS diode that has a clamping voltage (Vcl) exactly 30V or to be on the safe side a little under like 27V?
The clamping voltage should be higher than the normal operating voltage of the signal line, but low enough to protect the MOSFET.
And to make it even more complicated..
Another MOS FET I have has a built-in TVS diode for EMD protection. This MOS FET has also max 30V gate-source. But the built-in TVS has Breakdown voltage (Vbr) at 30V. So the Vcl must be a couple of more volts. Strange. Vbr is when the diode begins to conduct. And Vcl when it conduct fully. See table below. You might think that the built-in TVS should have Vcl at 30V in order to protect the MOS FET?
What is the trigger voltage if it’s something like 10 volts then a 15 volt diode would do
Sweden
All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
Design a TVS diode?
USA Electrical Forum
Krister Persson,
mainline,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
