J
jordi_ramis
Hi,
For months I'm looking for this piece without success:
A relay module powered by 220V and that can be controlled (toggled ON/OFF) by a wired NO (normally open) momentary switch (push button).
All I have found is some X10 micro modules that offer this functionallity but they very expensive as they are also X10. I'm looking for a simple way to ON/OFF a 220V appliance with a push button, the module has to be powered also by 220V I don't want to have to separate 12V (or similar) power supply.
Anyone know something like that?. Thanks a lot!.
A contactor can be made to latch on with a simple bit of wiring, granted you would also require a N/C stop switch in order to break the latch, cheers
I know is american but the theory is the same. One button for on and one for off.
I am obvoisly missing something here.
Can you please explain how that would work.
Having looked at the specs I am at a loss..................
A current is passed through a coil of wire. This attracts a piece of iron which moves a little lever with a hook on it.
The hook pulls on the teeth of a gear wheel one tooth at a time each time the coil gets current
This causes the relay to rotate the wheel in steps. This might then cause the wheel to turn electrical contacts on and off. - Google is your friend
Yes........ but the relay you referred to has not got that feature.... Google is indeed my friend LOL
From the "Product Information" tab for RS 511-1026:
16A 2NO step DIN relay, 230Vac
16A Step Relays - 20 Series
The 20 Series are available as DPST-NO or SPST-NO + SPST-NC step relays. On
each successive energisation of the relay coil the contacts will change state
thus providing a step or "flip flop" sequence of operation. An override test
button allows manual advancement of the step sequence and individual mechanical
flags provide visual indication of contact status.,Typical applications would
include the control of lighting where push on push off or sequential operation
is required, automatic opening and closing of doors, gates, etc. Use in portable
or battery powered equipment requiring contact status to be maintained without
continuous supply to the coil and functions where manual override operation is
desirable.
17.5mm wide (EN 50022) 35mm Din rail mount
housing
Manual test button and mechanical indicators
Minimum impulse
duration: 0.1sec
Maximum impulse duration: 1 hour
Insulation between coil
and contacts (1.2/50μ); 4kV
Nominal lamp rating: incandescent (230Vac);
2000W
Compensated fluorescent (230Vac); 750W
Temperature range: -40 to
+40°C
Protection category: IP20
Latching push button Schnieder do them, could then use standard relay or contactor will try and get you a part number
desirable.
housing
Minimum impulse
duration: 0.1sec
2000W
+40°C
Yep.. that will do....
Think this is the one in white they also do illuminated ones in various colours RS 380 5224
Hi, just had a look at the specification, looks right to me
The 20 Series are available as DPST-NO or SPST-NO + SPST-NC step relays. On each successive energisation of the relay coil the contacts will change state thus providing a step or "flip flop" sequence of operation.
Anypne has found this piece?
jordi_ramis,
jordi_ramis,
