Discuss Can anyone answer what happens with Eicr reports done after the deadline 1st April in the UK Electrical Forum area at ElectriciansForums.net
Also on the flip side landlords have to deal with unreliable, incompetent, overpriced electricians so I see it from their side also.
The problem is from the landlords perspective how do you determine the quality and accuracy of the EICR your presented with, then there is the cheap EICR with possibly unnecessary codes and then the overpriced remedials.
Before you even get the EICR you have to negotiate the minefield of how you choose a contractor to do your EICR and there doesn't seem to be any guarantee that choosing a CPS approved contractor will get you a properly and diligently carried out EICR by a suitably qualified and experienced electrician
In general terms most landlords already have a trusted electrician/tradesman who has carried out work for them over the past few years so I donā€™t see it as being a ā€œminefieldā€ unless youā€™ve been fortunate enough to have no maintenance work required or unless youā€™ve had ā€œDIY DAVEā€ to do the remidial work. He flicks the switch and the toilet flushes ? I donā€™t see it as being a problem there is a small minority of electricians who arenā€™t up to scratch same as the Landlords so itā€™s not a major issue really is it. Plenty of high standard electricians who will conduct an EICR to the required standards as set out in BS7671
Why canā€™t I put a thumbs down to this one Iā€™m not the best on here but Iā€™ve had a couple do so with my comments but donā€™t seem to be able to when I disagree with a comment ?ā€ā™‚ļø
Reply to Can anyone answer what happens with Eicr reports done after the deadline 1st April in the UK Electrical Forum area at ElectriciansForums.net
When we consider EICR reports for the Private Rented Sector, we usually think an electrician completing any EICR should be qualified and...
18K
  • Locked
Hi, we need some advice on our scenario with regards to our rewire plan. I will get this out of the way first... We are planning to put the house...
5K
Recently read a thread on the forum that I thought I'd bring to the attention of others. Hopefully it'll help cut out scamming in the industry, if...
5K
M
what did you do once you gained your level 3 electrical installation 2365?.I had college 2 days a week and i worked the other 3 days a week for a...
16K
Mike Blair
M
