Discuss Ceiling box too small in the UK Electrical Forum area at ElectriciansForums.net
Bchris
Hi
I have ceiling boxes in my garage for old fluorescent lights. I want to install a single outlet in them to support new led lights. The existing boxes are round and the screw holes are 2.75 “ apart. I can’t find a way to adapt a 4” outlet plate to this box. Is there an adapter available?
I have attached pictures of the current setup and the desired single outlet.
Bill
Hi
Bill
Bill that receptacle in that cover is home made and not compliant with the NEC. My advise to you is go to Home Depot or Lowe’s and buy new plastic boxes and change them. That cover is made for an octagonal metal box. Please call an electrician to give you what you need. The boxes just cost around $ 5.00 and receptacles are not designed to support nothing
Hi yes I put that duplex abomination up. I was hoping to adapt the existing boxes with resizing rings. If the answer is to replace the boxes then that is the answer.
Thank you!
Bill
Thank you!
Bill
You are welcome Bill and have a great day and good luck
Reply to Ceiling box too small in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
New construction in USA. I think that the builder put ceiling fan rated boxes in the ceiling. But when I remove the cover, I see a strange box...
4K
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
I would like to add a flood light camera and outdoor outlet to the front of my house where there is no existing wiring. I plan to get power from...
I'm taking a look at the 120v wiring in an old travel trailer that I recently bought, and plan to live in full time soon. It has some quirks that...
