G
GPack
I finished a survey today that has the potential for 10 x 250W Sanyos on the South side and 6 and the west side. With the distributors getting tighter on the 3.68kW per phase I am starting to look seriously at the fronius 3.5plus inverter that limits the output AC to 3.6kW and so should allow me to still fit and inform. Does the Fronius allow me to fit two different size strings? I have never used Fronius before. I have put it through the Fronius configuration software but it only comes up with two equal length strings? I'm used to using the the sunny boy 4000TL but this would produce more than 16A. There is such a different attude from the same DNO but from different parts of the region as to the process they go through to assess suitabliity it is making it virtually impossible to have a fixed process.
Thanks for your help
