Discuss Larger than Required cable Size - Is this OK. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Here's the situation. For whatever reason this domestic installation has ended up with a washing machine hard wire to a fused, switched (with neon) switch (that was obviously once a cooker switch) supplied by a 10mm T&E on a 16A MCB. A 13A fuse is installed in the switch. The cooker (which has a manufacturers supplied 3 pin plug) is plugged into what was obviously the old washing machine socket outlet beneath the work surface. The cooker switch has no labelling to say "cooker", or "washing machine" come to that. The occupier is quite happy that the washing machine is plugged into the switch. Bizarre I agree but is this OK?
The cable is suitably rated for the load! and is protected by a suitable breaker can't see a problem.
I would not install it like that because of cost, but at least the cable will never overheat.
So long as the cooker is not overloading the ring OK.
Hi on kithen refurbs i have often made use of a redundent cooker circuit and ither had a socket there or fused spur nothing wrong with it just put a note on board that that circuit is supplying a socket in kitchen
if you have label machine well yes that would be a good idea ,so many times i have worked in domestic installations where fused spurs are un labeled and spend time trying to locate what they are supplying only takes seconds to identifie i allways do mine
Local isolation which is "obvious" doesn't need labelling. In this case, I think it would be a good idea. Nothing wrong with larger-than-needed cable, it just isn't cost-effective on new installs.
Reply to Larger than Required cable Size - Is this OK. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind...
Hello everyone, I've got a new oven and have a question about installing it. It's a 2.6kW 13A oven, and a cable from the 32A cooker circuit to...
Bit of advise if anyone has time.. I have a customer who brought a new kitchen from wrens. Customer has had the route to the kitsch redecorated...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi All, I'm looking at installing an induction hob in my kitchen (upgrade from gas) and I gather that it can be added to the cooker circuit if...
