Discuss Power for new security alarm in the UK Electrical Forum area at ElectriciansForums.net
pc1966
We are looking at getting a professionally installed alarm to keep insurer's happier, and that will need a power feed which (miraculously) we had always planned and the RCBO is in our TPN board ready for it. However, I would rather not have the installers working in there for various reasons even though the quote says "Electrical connection to controls (24hr unswitched, fused outlet) will be supplied by [company]" so I plan to fit an outlet for it.
I was thinking of the MK K963KOALM FCU that has a key-switch and secured fuse holder:
So a few questions for folks on the forum:
  • Am I right that DP switching is normally required for any alarm maintenance, even though they say unswitched?
  • Is the key-switch on that model the same as the MK grid switch units?
  • Anyone know of what screwdriver fits the fuse's security "snake eyes" screw, or if it can be replaced with a normal slotted screw off another MK FCU?
TL;DR How best to feed an alarm panel?
For a TN system you just need an unswitched fuse connection unit, intruder alarms tend to have unswitched to prevent unauthorised operation.
OK, so just remove (and lock as needed) the fuse holder out?
In our case the panel and FCU will only be accessible by authorised folk anyway, so 'tamper resistant' is not as important as 'not accidentally switched off by leaning on it'.
I maybe should have added we have a 300mA delay RCD incomer and the Hager RCBO are SP switching, so I also would prefer the DP switch in case of isolating N-E faults in the unit.
Reply to Power for new security alarm in the UK Electrical Forum area at ElectriciansForums.net
Hi guys and girls, I'm newly qualified and want to confirm my method is sound before I commence any work. I'm registered with my CPS so can...
10K
Hello all, I would appreciate some advice on safely working with wires downstream of a fused connection unit (FCU). Some background: An...
Hi all, new to this forum, but t thought I'd join up, hoping for some assistance. I've just installed a Texecom prem 48. All with EOL wiring...
5K
Hello all I'm new to this forum and have recently joined due to a lot of threads here have been quite interesting and many have very good answers...
4K
Sam cook
Both Basic & Fault Protection SELV – if anything is provided by SELV, this gets a tick, otherwise N/A. Examples would be 12v extractor fan or 12v...
7K
