Yes it does have a thermostat but when it turns on, it turns on full blast, all 1500W or I can put it on the lower setting which would use 1000W whenever running.
Here is my dilemma: I run a compressor inside my work trailer, and so I run a power cord to the trailer from whatever house I'm working on. Thing is, compressors don't run very well at temperatures below 0 Celsius, and they they don't run at all below -20 Celsius. So I put the compressor inside an insulated box and I heat that box to keep it around 5-10 Celsius.
Now, I run chargers for my cordless tools and some lights inside the trailer. They can all be handled by the power I bring in. But when I add the heater, I keep tripping the breaker. I need tohave the heater run at lower wattage, which you tell me isn't possible.
So here goes plan B)
The two items that run the most power are the compressor and the heater. So what I was thinking is maybe I could rig a thermostat inside the heater/compressor box. But a thermostat would simply be turning on the heater at a given temperature, which would trip the breaker, should the compressor be running at the same time.
So would it be possible to have a thermostat that would switch the power from the compressor, and turn it to the heater, and then turn it back to the compressor when the heater is done running?
I want to have both the heater and the compressor running, but not at the same time. I need the compressor to shut down while the heater is running.
Any ideas?
