Discuss Shunt trip in a domestic CU? Looking for a complaint way of remotely switching off power in the UK Electrical Forum area at ElectriciansForums.net
Thanks for all your help, so basically i can ask someone to install a DP isolator and a contactor between the power supply and my CU?
Answering your questions, the house is a private owned dwelling, F/A does have backup power, im not modifying the gas installation whatsover, the (battery powered) servomechanism is installed on the top of main valve and physically moves the handle. I dont think i need to submit a notification nor if it does need to comply with any rules but i will have a boiler replaced soon so i will consult with a gas safe engineer prior to installing it.
If you do engage an electrician to install an DP isolator and contactor, and if your consumer unit is currently plastic, you might also ask them to quote for changing your consumer unit to meet the requirements of the 17th Edition Amendment 3. Fitting one of the EnviroBurst tubes would further improve the safety of an Amendment 3 consumer unit.
Actually it is plastic and ive been thinking about replacing it. I never heard about enviroburst tubes before, but that's definitely something i would love to have installed (if i will have space for it of course). Do you know roughly how much the complete system can cost?
Theoretically, there should be no need to upgrade to an Amendment 3 CU if you are just adding an enviroburst tube.
Well apparently metal ones are much safer if installed correctly, why would i want to pass on that? I just cannot do everything at once.
Ask anyone on here. Plastic ones are safe, as long as they are installed properly.
If you wish to change to the metal ones then by all means do so.
You do realise that by adding more electrical gizmos you are actually increasing the risk of an electrical fire. Shutting off the electrical system is pointless, once a fire has started it will make absolutely no difference to the fire. It maybe safer for the fire fighters but that is the only benefit.
Agree - it's a matter of statistics, the more things to go wrong etc. @Astro if I may ask, what has caused you to feel this way? My 20p worth is to think through why you believe there may be fire and address those causes directly. Clear out combustibles. Get experienced tradesfolk to inspect, report, repair or replace anything suspect.
Reply to Shunt trip in a domestic CU? Looking for a complaint way of remotely switching off power in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
BEFORE I pull my hair out looking over a gazillion google results..... wondered if anyone here has come across a device that will do something...
