Discuss Simplex control panel in the DIY Electrical Advice area at ElectriciansForums.net
Hello.
Could someone help me with installation because I’m a electric noob.
I got this beauty:
50579
50580
5058250583
And I need to connect this pump:
Volts 115
Amps 10.7
HP 1/2
Hz 60
Do I need any disconnect? Or can I just connect this panel alarm and pump to tandem breaker HOMT2020 120/240V 20amp?
Thanks for any help
Reply to Simplex control panel in the DIY Electrical Advice area at ElectriciansForums.net
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
