N
nicebutdim
The thread is about two points:
2) Manufacturers not honouring warrantees because a moulded plug is cut off to hard wire the appliance or fit a round pin fuseless 15A plug.
Which manufacturers are you referring to and on what basis have they invalidated warranties?
If the manufacturer stipulates that an appliance must be fused, then this requirement is met as you have an FCU in place. It's possible that they might refuse to honour any warranty claim on their fitted flex, but they'd be hard pressed to invalidate an appliance warranty on this basis.
Not sure your thinking this through as the very suggestion is indefensible. If I buy a new car and subsequently modify the suspension, it is quite possible that any claim for failure of suspension components bushes/joints etc will be refused, but warranty of engine/transmission/electrical components will remain intact. In order for a manufacturer to refuse to honour a warranty claim, they must demonstrate a valid reason for doing so and removal of an appliance plug certainly doesn't meet that criteria.
