R
RenatSha
There was a poor connection in this outlet. The clamps in the outlet are loose. The contact has warmed up and the socket has melted!
Only had to call out the DNO once when <whistles innocently> I managed to blow the main fuse. As there was no smoke, I was told "within 3 hours". But they refused to take my number - why would they, after all I'm on site; but they did insist on getting the householder's number (which they checked against their records) - so of course they contacted the householder who was at work.That's always worked for me. Mention smoke, and they're on site within the hour.
There are a number of possibilities.I have never had to play with an electric welder (other than a hour or two training as a student) so I would assume the high current secondary is not earthed to avoid a direct burn-out of the welder's earth. Or is it?
So was it two metal objects linked via conduit/CPC, and the welder's clamp was on one and the electrode arcing to the other?
I have one and have used it in the last week. Was doing some repairs to my Ifor Williams trailer and the gas ran out on the MIG, so had to dig out the old faithful.Might still have one of those welders - must check...
Hello, I wanna say that one of the biggest causes of frequent circuit breaker tripping is the overloading of power boards. Most homes and apartments, even newer ones, don’t have enough power points to cater to, for example, a complete home entertainment unit setup. If circuit breakers in your home are tripping frequently, it could be down to circuit overload.
It is, if you look at the buses.Member in question is in Islamabad, where it seems overloading is more common than in the UK.
I have a pair of those wire strippers.I realise these pictures aren't as spectacular as the others but they do show how powerful 230V can be. Plus it's a very real outcome if safe isolation isn't adhered to.
If a L-N or L-E short at 230v can take even a little chunk out of steel alloy, hardened with vanadium, then I hate to think what it would do to a persons hand/arm holding a pair of non VDE pliers.
These are my (now spare) side cutters after I cut through a live cable some years ago (whilst my mind was busy elsewhere, thinking about a difficult relationship with a gorgeous yet crazy woman.). We must keep our minds on the job!
View attachment 84131 View attachment 84132
Most sparks have or have had cutters to compare, I’d wager.I realise these pictures aren't as spectacular as the others but they do show how powerful 230V can be. Plus it's a very real outcome if safe isolation isn't adhered to.
I'll wager that all the sparks here have converted side cutters to wire strippers!I realise these pictures aren't as spectacular as the others but they do show how powerful 230V can be. Plus it's a very real outcome if safe isolation isn't adhered to.
Most will not admit to it.I'll wager that all the sparks here have converted side cutters to wire strippers!
Since I did my second ones I've kept a new pair in the bag hoping I'll never have to take them off the card!
Had a similar one to this, but with a washing machine. Before the few days were up, they had tried to repair it themselves, and the lady of the house had electrocuted herself.unplug the drier and don't use it. I will be with you on Friday morning (4 days from the call)
Turns up on Friday morning to find they had still been using the drier
