La Poste
Greetings.
I have a few questions about satellite and freeview.
I have a freesat dish and also an aerial on the roof on a property and I want to make sure they are working OK.
I have connected up the freesat using a Goodmans free sat box that is not particularly reliable so I am ditching the Goodmans for a Humax FOXSAT-HD as I have read quite good reviews about it.
I want to change the satellite single LNB to a double or maybe quad so I can supply two rooms with two freesat supplies each.
I also have an aerial on the roof and seeing as it is already there I might as well make use of it and drop a cable down so that each room has freesat and also free view supplied, the aerial I will do at a later date.
The cable I want to use for the satellite is Philex PF100 retailing at £14.99 for 25 metres because it's the first one I saw on amazon.
I have a question, the satellite is already lined up but maybe it could do with tweaking and the aerial I am not sure of.
Are these cheap £10 satellite and also cheap £10 aerial signal strength meters any good or are they a waste of time and money?
I was thinking of maybe fine tuning the dish and also I am not really sure if the aerial is lined up so I am thinking of using an aerial signal meter to test it.
Reading all this what do you think?
Are wallplates best avoided with freesat and is it best to just leave the cable trailing through the wall?
And one more question, are universal LNB's really universal or do you have to be careful and buy the correct one for the dish?
It's a lot of questions I know so thanks for reading.
