Discuss Are CE and electrical type stickers a legal requirment. in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
V
volta
A customer wanted about 40 arcade gaming machines testing none of which had been tested before even though many were well over 10 years old. None were marked up with CE or electrical type markings of any kind but were in fact class one earthed and all had IEC leads. It soon became clear that many were going to fail the earth bond test due mainly to lack of maintenance such as loose internal earth bonding, but many had no earth wires attached to external metal surfaces at all.
My question is. Should the machines carry a CE and electrical type sticker to comply with regulations.
I am certain the the CE mark is now required for all European sold new items, however it was probably not required at the time the machines were made.
The voltage / current / wattage information is now required on all new electrical items sold, however I do not know when this was introduced.
As they do not have markings at present then they would not now need to be marked unless they were re-engineered and sold as new.
Does the external metal require earthing?? is it suitably isolated from the incoming supply and im under the assumption that unless it is evident earthing is missing and should be their it may be the case that the control system would be SELV or similar. but don't quote me on that.
Some cases were metal some were MDF or a mix of the two. Some had earth wires to external metal and some similar machines had non. With no electrical markings it was difficult to know just what was inside. The maintenance guy opened up the three I failed and I advised him to attach earth wires to metal cases and external metal surfaces as part of a maintenance programme. Surprisingly they pack allot of electronics into these gaming machines when compared to something like an LCD TV. I guess SELV could be used on some, but which ones?
Reply to Are CE and electrical type stickers a legal requirment. in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
  • Locked
5K
I'm new to this but stuck with an issue, so I'm looking for some help wherever possible. I have just completed a rewire, which I have a potential...
I installed outdoor lighting and outlets. I finished this past year. I passed my inspection on April 2022. I was so pleased, BUT now the circuit...
