Discuss Car heater electrics - wrx 2003 impreza in the Auto Electrician Forum area at ElectriciansForums.net
Don’t know if anyone can help me. My car heater blower is getting no power until the car gets up to running temperature only then will it kick in. Once up to running temp it works great on all settings. I have changed relay, resistor and the motor but it’s still the same… any ideas?
I run a BMW, slightly older than your car, and what you describe is almost normal behaviour. The heater won't push out much air until it ha some heat to push out, otherwise it would be blowing cold air at you in an already cold cabin. Having said that, the fan does run slowly with a cold engine, just ventilating the cabin, without causing a draught, so maybe it's that part that has failed on yours
Thanks Brian, I don’t think the Subaru is like this normally though, if u set full power on blower even when cold it should blow cold at full speed. Not good when it’s misting in this weather. I have to drive a mile before it will do anything..😩 just can’t get my head round it. All I can think to change now is the heater control cluster but I don’t see how the heat of the engine can affect the heater motor Power supply
Reply to Car heater electrics - wrx 2003 impreza in the Auto Electrician Forum area at ElectriciansForums.net
I have a 2 year old 2000w electric panel heater. Devola Designer 2kW Smart Glass Panel Heater with Timer White - DVPW2000WH -...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hello I'm Ronald Alliy, I have current came up with what I believe is a Infinite Electricity source. Attached is my proof. I'm a noob at blender...
M
The idea of having electrical power from 240volt AC sockets in a sectional building not on the national grid is becoming popular among those who...
