Discuss Channelling cables in the plaster of ceilings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have been doing some subbying work for an NICEIC approved sparks. He will channel out the plaster of ceilings to run new cables in.
For example, today there was on light in a ceiling in an corridor and we were removing this and replacing with 4 spotlights. So the spark said to take out the plaster under the joists and lay the cable in. I wasnt happy about this but its his job and his name on the cert.
I suggested that this wasnt a good idea and shouldnt be done. He said find me a reg to say you cant do it. So I have looked in the BYB, in particular 522.6.201 to 522.6.204. As the joists are not being notched or drilled there is no problem there. 522.6.202 and 522.6.203 are refering to cables buried in walls.
This leaves 522.6.201
the first line is in regard to the cable being run in such a position that it wont be damaged by contact with the floor or ceilings or fixings. This seems to me to be the only reg that outlaws the channeling of the ceiling. But if the ceiling is already installed the fixings wont damage the new cable.
I still think its bad practice to channel the ceilings but am getting a bit lost as to whether the regs allow it
had to do the same when fitting downlights with no access from above. personally i can't see why the ceilings should not have safe zones between fittings, just like walls.
I can see your point but at the moment they dont have safe zones in ceilings.
And what happens when someone puts some christmas decorations up and puts the drawing pin into the cables?
When stitching cables in ceilings you normally chisel or drill out a bit of the joist to have a bit of depth for the cable, 50mm from finished surface is the target.
I am not too fussed that safe zones do not exist in ceilings. Xmas decos would likely go around the edges adjacent to the wall. Other than that what else is likely to cause the ceiling to be drilled or drawing pins put in it... Ok, there are things like decorative kids canopies and funny bed pelmets I suppose.
To the OP, I would always preferably cut a narrow and say 20-30mm deep notch to put the cable in. I reckon a member of Joe Public would be more likely to put a nail through a switch drop, as only electricians seem to be aware of safe zones, which kinda defeats their purpose!
You are not permitted to cut in to the bottom surface of a joist according to part A
Really! Whoops my mentor 20 years ago did not mention that and I've been doing it ever since lol.
Ok the other way of doing it when you dont have any access from above is to:-
With a 78mm (or whatever reasonable size) hole saw, cut a hole a few inches before the joist. Now with a long 16mm or 20mm flat wood drill bit, drill a hole through the joist. Fish your cable from one ceiling hole to another. Keep the cut outs (biscuits), get a bit of wood, batten it across the hole and replace the biscuit. Leave it to the plaster to sort out or fill it in yourself using finishing plaster (takes a bit of practice btw). Sand it down if needed and paint, job done :wink:
Yep, and it makes sense when you think of how the loading from above will impart itself onto the joist below. In an old house with big 9x2" or whatever sized joists then I do not think a small notch would particularly lead to any future structural problems. I have seen many older joists cut to ribbons (usually by plumbers!) that are still holding strong. Not that it is best practise...
Worst I saw was some clever arse who decided to cut away three inches depth for 1000mm from two six inch deep joist so their shower tray would be flush with the floor above.
Reply to Channelling cables in the plaster of ceilings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Hi all, Our sparky has carried out first fix, twin and earth cables clipped to the block walls of our extension routed to each back box. His...
4K
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Trying to replace a single run, approx 3M with no bends, of a single 1.5mm twin & earth cable between 2 lighting points in a domestic space. Cable...
