Discuss Channelling cables in the plaster of ceilings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
With a 78mm (or whatever reasonable size) hole saw, cut a hole a few inches before the joist. Now with a long 16mm or 20mm flat wood drill bit, drill a hole through the joist. Fish your cable from one ceiling hole to another. Keep the cut outs (biscuits), get a bit of wood, batten it across the hole and replace the biscuit. Leave it to the plaster to sort out or fill it in yourself using finishing plaster (takes a bit of practice btw). Sand it down if needed and paint, job done :wink:
This is what I do except I use a 100mm hole saw and use my angle drill. He complained that I had ruined the ceiling. The plasterers sorted it out. He also made a valid point that was how do you know you are drilling in the correct position on the span of the joist without seeing the whole length.
You don't know for absoloute certain, but you should be able to identify where the walls are and measure the distance between them. Bearing in mind the positions of the holes are measured on the span not the length. The span being the distance between supports.
If a joist or beam is supported at both ends and again in the middle then it is over two spans, not one.
That interesting, I didnt know that.
What about those joists that get joined by overlapping mid way across a ceiling, does the same rule apply?
Easy, you use a stud finder or tap your knuckles on the ceiling. Hollow,,, hollow,,, hollow,,,, not hollow, that will be a joist!
To some customers this is rocket science!!!!
Span is the distance between supports, if the rule was concerned with the length then it would say length.
It doesn't matter how many joints there are, the span is still the distance between supports. Not that I've ever seen a joist with a joint in it mid span? Are you sure about this?
common on new builds with tgi or open span joists where future provisions for a lift has been installed.
I have only seen it 3 or 4 times. Maybe some builder had removed a wall incorrectly
Reply to Channelling cables in the plaster of ceilings in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Hi all, Our sparky has carried out first fix, twin and earth cables clipped to the block walls of our extension routed to each back box. His...
4K
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Trying to replace a single run, approx 3M with no bends, of a single 1.5mm twin & earth cable between 2 lighting points in a domestic space. Cable...
