i=p/u
Supporter
Dec 9, 2010
7,461
817
1,688
Northern Ireland
United Kingdom
is their a chance of damp getting in if you drill under door below ground level.... it will be filled in with compacted sand and paved afterwards
i plan to drill 20mm hole to pipe out along to put lights on wall outside????
i cant see a proble as the sand will be compacted can you see a problem or have you had trouble with this
If you drill below the damp course then you are in deep pooh .................. so under a door providing it's above the damp course your fine.
You would have to create a hydroscopic path around the DPC to cause problems.
Your cable through the foundations isn’t any different to the water, gas and supply cable.
i=p/u
Supporter
Northern Ireland
United Kingdom
drilling through under door
i=p/u,
Knobhead,
