dangermouse
Hi, I am new to the forum so firstly hello all. I have a basic understanding of auto electronics but have encountered a problem that is beyond me and need your help.
I am retrofitting a dynostart (startermotor/generator) to a dumper engine that was previously hand-crank start.
It is a Hitachi unit commonly used on petrol golf carts and RussianUral motorcycles!
The problem I have is that once the engine is running and chargingbegins, it is designed to send thecharge current back along the same cable used for the starting current.
So having started the engine, once I release the starter button (de-energising the starter solenoid) the circuit is broken and no charge can be returned to the battery.
The golf cart uses a constant duty starter- solenoid to overcome thiswith a more complex control unit.
According to my research theRussian Ural 650, however, uses a 'high current silicone rectifierdiode'across the switched/largesolenoid terminals allowing currentto return to the battery duringcharging but blocking it from trying to activate the starter motor.
This is where I am struggling and need your help. Sadly I cannotseem to source the unit used onthe Ural so I need to find acompatible diode.
It is a 12 volt system which can runup to around 14 volts when charging.
The dynstart generates 17amps max. The battery is a medium sized 45 amp- hour unit.
I have trawled diode supplier's sites but don't understand enough about how diode ratings etc. work to find a suitable one.
Can anyone advise me on a suitable diode rating/part number for this
application as i am a bit stuck now.
Sorry this is a bit long-winded but though a bit of background might be useful.
Any help/advise would be much appreciated.
