Discuss How Is A Time Clock Wired In A Consumer Unit To Operate Contactors To Control Mcbs For The Heating in the Central Heating Systems area at ElectriciansForums.net
W
WestMidsElectrical
Hi everyone, I'm very curious about economy 7 boards on electrical installations with time clock on din rail and the contactors. I have a photo to show exactly what I mean, now I want to know how does the time clock switch the contactor to allow the heaters to operate from economy 7 times, I do wire heating systems but would rather get expert advice regarding the consumer unit layout and wiring.
Appreciate if anyone could help!
My point is what board is the mcb fed of, and what would be the layout of the outgoing side of the contactors in the picture, in that set up, I've worked with time clocks and contactors would say couple of times however not for heating just for car park lights on a contactor overrided by a photocell, sorry mate just very curious
I presume the idea is - economy 7 without the meter being a dual one and they installed a board with heaters with a time clock operating in the hours of economy 7 times and the it switches the contactor to make this work, thought it was clever installation but wanted more explanation and diagrams why,, I've saw the contactors used on pv installations but was quite confused the reasons behind it!
The board is set up to switch on when the contactor operates.
The timer is set to operate within the Economy seven time periods and then switches the contactor coil.
The board is then powered up and the heaters will start to operate (assuming they are locally switched on).
When the Economy seven time stops the timer switches off and so powers down the coil of the contactor that then switches the board off.
This is a diagram of an internally switched arrangement in one board along with other 24hr circuits.
The timer and contactor coil are protected by a circuit breaker on the 24hr side.
The heaters circuit breakers are powered only when the contactor is on.
Reply to How Is A Time Clock Wired In A Consumer Unit To Operate Contactors To Control Mcbs For The Heating in the Central Heating Systems area at ElectriciansForums.net
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
