Discuss Process for certifying work in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
Got a job for a friend in motion. Consumer unit change. Bonding is good and system had been tested so I'm confident no problems will occur with the introduction of RCD protection.
My question is, what's the process in getting the work certified. I'm qualified but not registered with a scheme of sorts.
Is it just a case of contacting building control and telling them of the proposed work and then laying a fee?
the building control fee round here is £300. if notin a scheme you're stuffed. pm sent.
Hi,before the help starts flowing....can i ask,what is a "friend in motion"? ;)
Not that kinda friend unfortunately ?
[automerge]1575702877[/automerge]
The schemes have really out the brakes on doing notifiable work without them. I know they are generally a good idea but the cost of notifying work to building control without them is just a con.
I recommend using a 3rd party certifier rather than building control, it'll almost certainly be cheaper. I would expect that when you go through BC, they probably just contract it out to a 3rd party certifier anyway, rather than having someone in-house that does it.
Have a read of my posts in this thread, which explains more:
It all depends on the local council as their fees vary massively.
Also depends on what qualifications you have too. If you’re up to date on the regs and have an inspection and testing qualification, they may well be happy for you to certify it and send it in to them.
I have found a 3rd party scheme near me who will notify for local trades for £40
Much cheaper than having to go through the council
Must be mad, still if they are daft enough then that’s their problem
I’m pretty sure that 3rd party notifications can only issue you with an EICR and not an EIC so you’d have to check that LABC are happy with that for the work too.
Not so, a 3rd party certifier will notify through their scheme (either NAPIT or STROMA). Building control will have no more to do with it than they would if the certifier was notifying their own work through their scheme, ie nothing.
[automerge]1575737197[/automerge]
That's about what I pay for small notifiable works, more for say a consumer unit change.
3rd party certifiers are rip offs, I contacted one in my area (Surrey) and he quoted; first fix visit £250, 2nd fix visit £250 and £40 to test every circuit, minimum charge of 10 circuits, total £900 min, plus VAT, it’s actually cheaper to pay the LBC fee. Said I can test all the circuits, NO, he has to test them if he is signing the EIC. :mad::mad::mad:
900 quid is a joke
Last time I checked Surrey BC charge £280
Ring around some more local 3rd party people and you will normally find they charge between £40-£200 in my area
Sounds fair enough to me with the £250 site visits.
Reply to Process for certifying work in the UK Electrical Forum area at ElectriciansForums.net
Hello. I have a quick question for registered sparks on here. Can/ will / do you certify notifiable work done by others? I guess I’d have to...
Hola! I’m in the process of renovating an apartment in Madrid. The consumer unit is fitted with an old 15amp ICP switch. I believe its function...
NAPIT Certification Scheme Third Party Certification
Is there anybody out there in NAPITs Third Party Certification Scheme who would be willing to certify a new consumer unit I am wanting to install...
Hi, I'm looking for some advice please. I'm not an electrician but have employed a registered qualified one to do some work for me and want to...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
