- Dec 2, 2021
- 1
- 0
- 31
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United States of America
- What type of forum member are you?
- Retired Electrician
I see circuit tracers priced from $25 to 1000s of dollars. I guess that the cheap ones won't do. I can find the circuit breaker. I want to find where the NM cables run inside the walls and perhaps ceilings, so that I have some hope of finding where it is mis-wired. So all I need is a tracer that can detect the cable (either energized or not) through a layer of 1/2" drywall up to 4" deep in the wall.
