These are the standard 'corrosive proof' fittings which any wholesaler stocks though,and what is presently installed.Snag is though these are not suitable for swimming pools according to the manufacturers,as the chlorine affect the enclosure.
You Sure?
I was just having a waffle on really sorry. I have tried googling it with no joy none are chlorine proof, surely the wholesales must know where to get them!
As i've stated above chlorine saturation in an indoor swimming pools environment is going to be very low, as will be the concentration of chlorine in the pool water. I can't remember installing any so-called special pool room lighting fittings in any of the indoor pools that have been involved in, apart from being totally enclosed plastic fittings. So the type of plastic fittings that are being suggested here should more than adequate/fit for purpose. It should be noticed that wirepuller has stated himself, that no visual signs of degradation is evident to the existing enclosed plastic fittings..
Manufactures from my experience can be fickle people to deal with, tending to always aire on the safe side when talking about anything outside of the norm... If this school swimming pool has a well vented through flow system, (either natural or forced air flow) then i really can't see any problem whatsoever. It would be a different matter if we were talking of manufacturing process where concentrations of chlorine can be high....
