- Dec 18, 2011
- 5,379
- 6,732
- 405,788
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
I'd like to understand a bit more about what actually gives you an electric shock. I think the more you understand something the safer you will be.
I have been taught that it is the current (amps) that gives you the shock, but this then confuses me with regard 12v equipment (lets say anything domestic - downlights for example using a transformer), as if the lights are 10W then:
Power = Voltage x Amps
10 = 12 x Amps
Amps = 10/12 = 0.83
If however the light were from the mains:
Amps = 10/230 = 0.04
So according to the maths a low voltage system uses more current and would be more dangerous as its amps that cause the shock. I know I'm missing something simple as this cant be right but I get a bit carried away with maths!
Could anyone explain this a little please?
10 = 12 x Amps
Amps = 10/12 = 0.83
