J
Jörn Ballentin
I want to lay conduit under a 100mm concrete kitchen floor slab that will be poured in a couple of weeks time (to complete a ring and connect a kitchen island). This will be in preparation for my electrician to do all wiring once the builders are done.
Does anyone know if I will need to use (very expensive) PVC sheeted steel conduit in this situation (LT-PVC FLEXIBLE CONDUIT 25mm | KOPEX | Conduit) or if normal PVC conduit (KOPEX - EF150022X10 - CONDUIT, FLEXIBLE, 25MM, 10M REEL: Amazon.co.uk: Electronics) will do given the 100mm concrete on top with no real danger of anyone accidentally digging up the cable?
Also, given that it is encased in conduit and mechanically protected, will T+E cable be suitable or will I need SWA?
