L
Leesparkykent
Agree, gonna have a look in abit as I'm nosy ,but do you remember where you found this info Reg Ect.
Its common sense really but 433 covers protection against overload current. 433.1, 433.1.1 and so on.
OK, thanks to everyone for your advice.
The thread can be closed now as far as I'm concerned.
I could not agree more on a soundly built house full of insulation, and save on my bills, don't care what it's made of, straw & mud wouldn't bother me. Not sure whay the OP wants a 12kw water to wash up the dishes for? The Redring one I looked at by the way, said unsuitable for kitchen sinks? Good advice re the gas supply though, future proofing. Although, if you believe the headlines, no use after 2030!Don't be disheartened, many trades in this Country don't like change, most builders still think block/brick build is the only way - ask them about air tightness testing and you'll get the same belligerent responses as you've seen here.
Your instantaneous heater proposal is sound - heat at the point of use, and only heat what you need is a concept clearly lost so far in this thread.
But do ensure you pander to those who might live in the house after you by ensuring gas is at least piped to the likely areas of use, you don't need to have a supply, just a feed from your utility box.
a couple of small unvented water heaters which hold a small amount of water with thermostatic control and consuming under 3kW each such as the Ariston type would surely be far more sensible ?
Do you keep a kettle of boiling water ready at all times for those few times during the day when you want a brew ?
No but I don't start up a small nuclear reactor to boil a couple of pints of water either.
And unlike a kettle the type of heater I described is very well insulated so once the thermostat temp is reached the water will stay hot for a long time without further current being drawn.
10l maximum ? then its 10? minutes wait till for more hot water - that's the reason folks want high current instantaneous heating
You can now get a tap with a built in 3kW instantaneous heater to provide boiling water on tap, so why would you need a 12kW heater to get water at a around 60degrees?
Isn't 10 litres enough to wash your hands, have a shave or wash a few dishes then ?
Probably, but doing a few sinks worth of dishes could get tedious
What's the flow rate ?
How many litres does the average kitchen sink hold ?
Get a dishwasher :smiley2:Probably, but doing a few sinks worth of dishes could get tedious
How on earth should I know? You'd need the flow rate at the point of connection to find out what it will be out of the tap!
From experience the boiling water is not noticeably slower than the regular hot from a tap.
Again how the hell should I know the average volume of a kitchen sink?
I'm only asking why such a large amount of power is necessary to achieve the same result as can be achieve with much less power?
I thought the whole point of this was energy efficiency?
Using a few sinks worth of dishes to cook a meal is not very energy efficient when meals can be cooked with far fewer dishes!
Post a link please, I'll find its flow rate - there's no point getting excited over it if its flow rate is 2 dribbles a fortnight.
Maybe some folks want a meal that doesn't just consist of toast and beans
Quooker is the best known one, but there are other brands out there.
??? That's just daft, you can cook a while roast dinner with just a few pots and pans if you know what you are doing.
OK let's assume you can do what no one I've ever known has been able to do ........
So what about the 2,4 or 6 folks who sit down to scoff that roast - will they be using any plates, knives, forks, spoons, then there's pudding, that's maybe 6 more bowls and spoons, then there's a cuppa afterwards, then the cheeses and more drinkies ... that's a good few sinks of washing up, average domestic sink capacity of say 25 litres ?
rough calculation - 10 litres of water, say its incoming at 10 degrees, 90 degrees rise required - 3kW element - that's nearer to 20 minutes to raise that volume to near boiling
You do your washing up in boiling water?
Why not just have a unvented cylinder with an immersion or even twin immersion? and you could run the shower off it. Small solar thermal setup on the roof to keep it topped up throughout the day with something like the solar iboost so when the pv is producing more than what's being used it also heats the hot water.
Great, until the sun doesn't shine - and then you've got heat loss from the cylinder and the dead legs - which most folks don't seem to mind wasting their money on living in their conventional energy inefficient home, but that's not what the OP wants to build.
OK - someone said I had lost interest in the thread. Nope. I'm just not willing to debate the often ill informed comments that have been posted along with the insightful ones.
Only Sean and spinlondon apparently have any real experience of this type of build. Other than the eminently sensible electrical design advice that has been given which I have already said is making me seriously consider changing the rating of the water heaters, 80% of the posts are just argumentative and "you don't want to do it like that". I said I didn't want to debate the design scenario, but there appears to be a lot of interest (or maybe not).
I understand the reasons why folks don't know or haven't considered alternative build or design scenarios. I also understand the uselessness of many of the alternatives that are out there which are only really useful in two cases.
1) Where the environment is harsh and requires it
2) Where the technologies are being fitted as part of a refurb rather than a new build.
Where we live the average winter temperature doesn't fall below 3.7° - Plymouth, England Climate Plymouth, England Temperatures Plymouth, England Weather Averages
As a result, high levels of insulation and air tightness coupled with an efficient MVHR should mean no heating is required over that generated naturally within the home.
These things are calculated properly and scientifically and do not require opinion. If top up heating does prove a requirement, I think you'd agree that adding a 1.5kw panel heater somewhere shouldn't prove too challenging!!!
As it is my home, my opinion on the quantity and frequency of hot water that will be required is such that showering and hand washing are all that should take place. We wash our clothes in a washing machine. We wash our dishes in a dishwasher. What you might do is a matter for you.
We are trying to build a 21st century home - not an 19th century one. We are using state of the art knowledge and techniques. Only one other home has been built in the UK to date using the build method we are using. That was the proof of concept in Scotland. Ours will be the first commercially built home after that.
I have also effectively been called a liar - the first time it was reasonable and put in a polite way and I understood and answered it. After that it is just offensive.
In short, while you guys unquestionably know more about electrical science than I. I am not going to take lessons in the overall design concept or in day to day living paradigms from you, thanks very much.
Finally, again my genuine appreciation to the posters who have helped with their constructive suggestions and observations.
Probably because you did little of nothing to persuade the masses that you actually have a sparky involved.......
and what happens when all the air has been used up, and he's breathing in CO2?Back to a sensible question - you made a statement about the property being "sealed" or similar - how do you get rid of unwanted moisture?
